Autor Tema: ScanGauge 2! Todos los datos que podamos imaginar de nuestro coche!  (Leído 2393 veces)
sevilla_es
« en: 20 de Septiembre de 2008, 18:22:11 pm »
  Mirando por internet me encontre con este cacharrillo que aporta una informacion bestial sobre todo el coche solo vale 159 euros incluidos portes y sirve casi para todos los coches con centralita y por ejemplo para GM es capaz de mostrar todo esto:
 P1031 Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
P1032 Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
P1101 Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow
P1105 Secondary Vacuum Sensor Circuit
P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108 BARO to MAP Sensor Comparison Too High
P1109 Secondary Port Throttle System
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113 Intake Resonance Switchover Solenoid Control Circuit
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
P1116 ECT Signal Unstable or Intermittent
P1117 Engine Coolant Temp. Signal Out-Of-Range Low
P1118 Engine Coolant Temp. Signal Out-Of-Range High
P1119 ECT Signal Out-Of-Range With TFT Sensor
P1120 Throttle Position (TP) Sensor 1 Circuit
P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1125 Accelerator Pedal Position (APP) System
P1130 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1
P1131 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2
P1132 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
P1135 Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1
P1136 Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1
P1137 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
P1138 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage
P1139 Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2
P1140 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2
P1141 Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P1143 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage
P1144 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage
P1145 Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
P1155 Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1
P1156 Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1
P1157 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage
P1158 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage
P1159 Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2
 ......... etc... etc....
  por aqui sigue la lista: http://www.scangauge.es/DTC/GM.html
El Ultra Compacto
3-in-one Automotive Computer
Scan Tool - Trip Computer - Digital Gauges
La computadora integrada del viaje proporciona la regeneración en tiempo real mientras que simultáneamente sigue tres sistemas de datos del viaje. Las galgas de Digital le dan los datos en tiempo real para su vehículo y la herramienta incorporada de la exploración permite que usted lea códigos del apuro y que diagnostique problemas potencialmente costosos antes de que salgan de la mano.
Todo el esto en un pequeño y simple instalar la unidad que se puede mover fácilmente desde el vehículo al vehículo.
Por aqui hay mas fotos del bicho:
Y este es el enlace a quien lo vende:
http://www.scangauge.es/products/product.html
 A ver que os parece. O0
Re: ScanGauge 2! Todos los datos que podamos imaginar de nuestro coche!
« Respuesta #1 en: 20 de Septiembre de 2008, 22:37:40 pm »
Por lo que se ve hace muchas cosas, aunque no entienda ni la mitad ;D ;D
nachus69
« Respuesta #2 en: 24 de Septiembre de 2008, 17:34:09 pm »
 :'( no se pa que sirve
« Respuesta #3 en: 24 de Septiembre de 2008, 17:58:44 pm »
la informacion que esta en english de ese?
S´ta majo el aparatejo!!!
Buen aporte!!  O0
« Respuesta #4 en: 24 de Septiembre de 2008, 22:43:43 pm »
para los que no tenemos ordenador de abordo hace todas las funciones de el O0 O0
« Respuesta #5 en: 24 de Septiembre de 2008, 22:45:45 pm »
Vaya canales mas raros que pilla ese TDT.
No conozco ni uno .....  >:D
 :DD :DD :DD :DD :DD
MADRUGA
« Respuesta #6 en: 24 de Septiembre de 2008, 23:16:12 pm »
A ver si va a ser un PPV.
En fin a mi todo lo que sean datos me mola
« Respuesta #7 en: 25 de Septiembre de 2008, 00:37:53 am »
 :o :o que pasada
nachus69
« Respuesta #8 en: 27 de Septiembre de 2008, 17:15:41 pm »
ok  :DD
xandaschurras
« Respuesta #9 en: 28 de Septiembre de 2008, 23:14:05 pm »
Pues esta ***,buen aporte, [plas] [plas] [plas] [plas] aunque para nosotros la inmesa mayoria no sirven para nada, para uno que entienda le saca provecho.
Lo que si echo en falta son la presion de aceite, temperatura de aceite y presion del turbo.
zaficor
« Respuesta #10 en: 30 de Septiembre de 2008, 00:21:27 am »
Yo con el indicador de temperatura del agua me conformaria...!! :'( :'(
quimico
« Respuesta #11 en: 01 de Octubre de 2008, 14:58:13 pm »
peor para que detecte todo eso el vehiculo tendra que tener los sensores pertinentes y que ademas que la centralita los interprete  :-\ :-\
ErDeLaZafi
« Respuesta #12 en: 04 de Noviembre de 2013, 09:44:06 am »
A mí me dá la temperatura del agua de la batería en el espejo retrovisor (que es donde me indica la presión de cada una de las 4 ruedas por separado)  O0.
