Autor Tema: Aceite especifico para Zafiras 2.0 and 2.2 DTI engines " Chupi, chupis.  (Leído 1594 veces)
Idigoras
Motul 8100 X-cess 5W40
Gasoline and Diesel engine oil
100% Synthetic.
TYPE OF USE
Specifically designed for powerful and recent cars fitted with high displacement engines, gasoline, Direct injection turbo Diesel and catalytic converters.
Numerous car maker approvals make this product multipurpose especially recommended when the car is under warranty.
Suitable for leaded or unleaded gasoline, Diesel fuels and LPG.
The OPEL/GM Diesel LL B-025 standard requires two main properties to the lubricant : high HTHS and very low volatility to drastically decrease oil consumption. Motul 8100 X-cess 5W-40 is especially recommended for OPEL 2.0 and 2.2 DTI engines (extended drain interval : computer on board).
Igual ya lo sabiais............. .
Dice que esta pensado para que no os chupe nada de aceite. Es un aceite nuevo. Aunque sirve tambien para la B, la publicidad solo habla de la A.
Marca  OPEL
Modelo  Zafira 2.0Di/DTi (Zafira A)
Motor  DT
Año  1999-05
Aplicación Recomendación Capacidad (L)
Motor  (DT)   Best     8100 X-cess 5W-40        (s)  5.5
                  Better   6100 Synergie+ 10W-40   (s)
                  Good     4100 Turbolight 10W-40   (s)
http://www.ew2.lubesinfo.com/frameset.asp?sid=323&bid=188&sc=1323&langid=3
Re: Aceite especifico para Zafiras 2.0 and 2.2 DTI engines " Chupi, chupis.
« Respuesta #1 en: 19 de Febrero de 2008, 09:54:41 am »
y en €€€€ cuanto el litro?
Idigoras
« Respuesta #2 en: 19 de Febrero de 2008, 09:59:54 am »
Ni idea.
