Autor Tema: zafira no hace por arrancar  (Leído 456 veces)
whuey74
« en: 24 de Junio de 2016, 22:36:22 pm »
wenas estoi loko con mi zafi intento arrancar i hacepor arrancar y alos 2 segundos se para el intento de arrancar,quito el contacto y doi al contacto para volver a intentar arrancar y no hace por arrancar(solo suena un clip y se apaga todo el cuadro,pantalla de la rradio)como si tuera un corto.le he pasado el opcom y me arroja el codigo
-u2139-72
pego el log:
DIAGNOSTIC REPORT:
OP-COM 100219a
**********************ECU ID STARTS**********************
Source Address: CIM
Source Address: 0x00000245
Identifier: 0x010A
VIN: W0L0AHM758G067209
System name: VALEO A3300 CIM
Hardware number:13276153
Part Number:13276153
Software version number: M:10.62 S:01.00A
System description: VALEO0400
Hardware key number:  66KPK0
Programming Date: FFFFFFFF
Alpha code: ÿÿÿ
Manufacturing date: 20071115
Code Index and version: ÿÿÿ ÿÿ
Number of stored fault codes: 1
U2111 - CAN-Bus No Communication with EPS (Electrical Power Steering)
(00)  - Not present
**********************ECU ID ENDS**********************
Source Address: ECM
Source Address: 0x000007E0
Identifier: 0x1341
System name: Z19DT
Hardware number:81012656
Part Number:55575556
Software version number: HMPMS330_S
Hardware manufacturer number: 0281017064
System description: 1037505798P485_O27
System description: BOSCH0100
Type approval number: B06050
Hardware key number: H000001789
Programming Date: 20100426
System description: 0x00007040
Alpha code: SB
Software version: HO27JDB2
ECU variant coding: 0x000010C5
P0621 - Generator Lamp "L" Control Circuit Malfunction
(01)  - Present
Source Address: ABS/TC/ESP
Source Address: 0x00000243
Identifier: 0x049E
System name: ESP MK60
Hardware number:16090000
Part Number:13244860
Software version number: D3_RAA00009
System description: TEVES0300
Programming Date: 00000000
Alpha code:
Manufacturing date: 20071031
ECU variant coding: 0x000054C0
No fault codes stored.
Source Address: EHPS
Source Address: 0x00000244
Identifier: 0x0203
System name: EHPS EP2 ZFLS
Part Number:13192897
Software version number: 7625379111  P531
System description: ZFLS 0011
Programming Date: 20202020
Alpha code:  JV
Manufacturing date: 00000000
Code Index and version: 003 01
Source Address: IPC
Source Address: 0x00000255
Identifier: 0x1107
System name: BCM/KOMBI-A3300
Part Number:13267544
Software version number: 7.655 35/06
System description: SIEM 0400
Hardware key number: 0000000000
Alpha code: FZ
Manufacturing date: 20071119
Code Index and version: 003 04
Number of stored fault codes: 7
B0670 - Airbag Telltale Circuit Malfunction
(00)  - Not present
B1375 - Switched System Voltage (Ignition ON) Not Plausible with CAN Signal
(04)  - Not present
P0500 - Wheel Speed Sensor Circuit Range/Performance
(71)  - Not present
P0654 - Engine Speed Signal Range/Performance
(71)  - Not present
P0550 - Mileage Circuit Range/Performance
(71)  - Not present
P0460 - Fuel Level Sensor Circuit Range/Performance
(71)  - Not present
P0115 - Engine Coolant Temperature Signal Range/Performance
(71)  - Not present
Source Address: AIRBAG SDM
Source Address: 0x00000257
Identifier: 0x0204
System name: MRSZ-Temic
Part Number:13246046
Software version number: A3300RG3 V 3.4.0
Hardware key number: ÿÿÿÿÿÿÿÿÿÿ
Alpha code: QX
Manufacturing date: 20071107
(00)  - Not present
Source Address: ECC
Source Address: 0x00000248
Identifier: 0x0401
System name: SAC A3370
Hardware number:13245112
Part Number:13247812
Software version number: 0AM75/05C61
System description: PREH 04
Alpha code:
Manufacturing date: 20071108
Code Index and version: 001 02
Source Address: UEC
Source Address: 0x00000250
Identifier: 0x0108
System name: FZM_LC INTEDIS
Hardware number:13220435
Part Number:13250232
Software version number: FZM_LC 7.00F00
System description: INTED0400
Alpha code:  KA
Number of stored fault codes: 2
B0575 - Fuel Level Sensor Circuit Low Voltage
(02)  - Not present
B3970 - <Unknown DTC>
(00)  - Present
Source Address: EHU
Source Address: 0x00000241
Identifier: 0x0209
System name: CD 30
Hardware number:13250919
Part Number:13263049
Software version number: 57306/-----
System description: DELPH0400
Alpha code: CP
Manufacturing date: 20071106
Code Index and version: 012 03
Audio Index and version:  031 03
Temperature Index and version: 027 01
Source Address: DIS
Source Address: 0x00000246
Identifier: 0x1101
System name: BID Delta
Hardware number:13276999
Part Number:13276999
Software version number: 7131-/-----
System description: BORG 0400
Alpha code: BR
Code Index and version: 008 03
U2139 - Invalid Data from CIM (Steering Column Module)
(71)  - Not present
Re:zafira no hace por arrancar
« Respuesta #1 en: 24 de Junio de 2016, 23:38:47 pm »
Como esta la bateria?
whuey74
« Respuesta #2 en: 25 de Junio de 2016, 09:27:08 am »
la bateria fue lo primero que comprobe,esta buena.tambien intente con otro coche y las pinzas,el resultado fue el mismo.
« Respuesta #3 en: 25 de Junio de 2016, 10:04:10 am »
Fisibles los habras revisado, supongo.
Y los cables de la  bateria donde se junta con los terminales ?
No sea que esten sulfatados y pase poca corriente, porque da la impresion que es algo de fallo electrico, vamos que le llega poca chicha y no da para alimentar como es debido todas las partes de la instalacion del coche
whuey74
« Respuesta #4 en: 25 de Junio de 2016, 11:18:06 am »
lo he revisado todo fusibles,reles,la beteria,
cuando giro la llave solo se escucha un clip y se apaga todo como si tubiera un corto.
« Respuesta #5 en: 25 de Junio de 2016, 11:51:20 am »
El único error que te sale present es el B3970 y el p0621 http://clubzafira.com/index.php/topic,20466.msg830325.html#msg830325 ese mismo error le salio a Yoda, al final  le cambiaron la centralita UEC o ECU entera
whuey74
« Respuesta #6 en: 25 de Junio de 2016, 14:25:38 pm »
he vuelto apasale el opcom:
OP-COM 100219a  - PC based diagnostic tool
OP-COM - CAN Communication Window> 2008 (8)|Zafira-B|Vehicle|Module/ECU Presence Check
Read Info...
Identifier: 0x0108
Alpha code:  KA
Software Freeze Date: 09.06.2006
Total number of fault codes:  5
B0283 - <Unknown DTC>
(00)  - Present
(02)  - Not present
B2750 - <Unknown DTC>
(00)  - Present
B3874 - Front Wiper On/Off Relay Circuit Malfunction
(00)  - Present
B3875 - Front Wiper Low/High Speed Relay Circuit Malfunction
Read Info...
Identifier: 0x0209
System name: CD 30
Alpha code: CP
Software Freeze Date: 11.10.2006/
Total number of fault codes:  2
U2101 - CAN-Bus (Mid Speed) Maximum Configuration List Not Programmed
(00)  - Not present
U2102 - CAN-Bus (Mid Speed) Maximum Configuration List not Complete
(00)  - Present
Read Info...
Identifier: 0x0209
System name: CD 30
Alpha code: CP
(00)  - Present
(00)  - Present
hay dos errores en concreto:
(00)  - Present
(00)  - Present
puede ser alguno de estos errores la causa de que no arranque.
whuey74
« Respuesta #7 en: 26 de Junio de 2016, 13:21:51 pm »
he traducido todos los fallos presentes:
-Limpiaparabrisas delantero fallo relé en el circuito de encendido-apagado
-Fallo en el circuito relé limpiaparabrisas delantero alta/baja velocidad
-Bus CAN (mediados de velocidad) máximo lista de configuración no se completó
-Lista de la configuración máxima de Bus CAN (mediados de velocidad) no programado
-Fallo en el circuito de descongelación eléctrico trasero
-Falla de comunicación de datos de clave de acceso
¿el ultimo a que se refiere?
« Respuesta #8 en: 27 de Junio de 2016, 00:02:10 am »
Tienes centralita REC? seguramente no y te pase como puse en el hilo que te puse, no tienes REC y todo va con la UEC y como a otros foreros te falla la UEC y cada vez tienes más fallos  L--i
