Autor Tema: {B} Exhaust temperature sensor on 1.9 cdti  (Leído 229 veces)
kaliope
« en: 15 de Noviembre de 2015, 22:03:09 pm »
Exhaust temperature sensors on 1.9 cdti. Description, part numbers, location, repalacement and differences between z19dt (120bhp) and z19dth (150bhp)
https://www.youtube.com/watch?v=HnzWHUFk_po
bws6
Re:{B} Exhaust temperature sensor on 1.9 cdti
« Respuesta #1 en: 15 de Noviembre de 2015, 23:18:57 pm »
Sensor de temperatura termostato no esta funcionandote bien
Enviado desde mi LG-D855 mediante Tapatalk
kaliope
« Respuesta #2 en: 16 de Noviembre de 2015, 07:19:39 am »
for the thermostat change see this video: https://www.youtube.com/watch?v=_MW5PyIfMzs
kaliope
« Respuesta #3 en: 17 de Noviembre de 2015, 16:49:25 pm »
Need to correct one thing as for the video above. It occurs there are two types of catalytic converters on both z19dt and z19dth, depending on if there is a DPF or not. If there isn’t, there is a lambda sensor fitted at the top. If there, however, is no DPF, there is a temperature sensor at the bottom on the left on both z19dt and dth. The pictures below show z19dth catalytic converters from a Zafira with DPF on left and with no DPF on the right.
