Me he encontrado con esto por la red, se llama unos 605$ unos 460€ aprox., a quien le pueda interesar le paso los datos del vendedor, supongo que si se piden varios se podra sacar algun precio bueno, el precio es puesto en casa
estas son las caracteristicas:* ALL-IN-ONE DVD SYSTEM FOR OPEL ASTRA
* 6.5'' Digital 800*RGB*480 TFT Monitor
* Steering Wheel Control
* Built-in GPS system (OS: WINCE 5.0)
* Dualzone function (Listen FM/CD while watching GPS image)
* Built-in Bluetooth
* iPod control function
* Micro SD card slot
* Blue button backlight
* Auto Dimmer(Standard/bright/soft/customer video mode)
* Play DVD/ DivX/MP4/VCD/CD/MP3
* Built-in TV Receiver
* DVB-T Tuner (Optional,DVB-T box [DVB-T-03], operate by Touch screen)
* Built-in FM/AM Radio
* Built-in 4X50W Amplifier
* Super Bass output 5.1 Mode
* 1 AV Output(3 Zone) 1 AV Input
* Car Camera input
* Electronic Anti-Shock Protection
Special Function:
1. According to the original car design, without crack installation, don’t cut line and only need to insert the socket into the original plug when you install.
2. To see the map on the screen and to hear a radio/CD in the background
3. Three Zone function, listening to Radio in the front and watching DVD/TV from the back Monitor at the same time
General Section:
1) Power Supply: DC12V(10.8V-15.8V)
2) Current Consumption: Less Than 10A
3) Operational Temperature Range: -20℃ to +85℃
Audio Section:
1) Rated Output: 4ch ×23W (1KHz, 1﹪, 4Ω)
2) Maximum Power Output: 4ch×50W
3) Rated Speaker Impedance: 4Ω
4) Pre-AMP Output Voltage: 2Vrms
5) Pre-AMP Output Impedance: <220Ω
6) AV Input/Output Section
7) Video: 1 Vp-p(75Ω)
Audio: 500mVrms
Monitor Section:
1) Picture Size: 6.95 inche
2) Display System: TFT LCD panel
3) Video System: PAL / NTSC
4) Brightness: 400cd/㎡
FM Stereo Radio Section:
Frequency Range:
1) U.S.Standard: 87.9-107.9MHz
2) Outside U.S.: 87.5-108.0MHz
3) Usable Sensitivity: 5dBμV(S/N=30dB)
4) S/N ratio: >60dB
TV Tuner Section:
1) Colour System: NTSC, PAL-B/G, PAL-I, PAL-D/K,PAL-M,PAL-N
2) Channel Selection System:PLL Frequency Synthesizer System
3) Usable Sensitivity: 41dBuV
Optional:
1) Built-in GPS and MAP (optional)
2) DVD/CD Changer.
3) Digital TV Tuner (DVB-T-03)
The following map of countries are available now:
EU MAP:Aaustria, Switzerland, Liechtenstein, Italy, Belgium, Netherlands, Luxemburg, France, Andora, Monaco, Spain, Germany, Greece, Vatican, San Marino, Denmark, Finland, Norway, Sweden, Portugal, Gibralter, Channel Island, England, Ireland, Lsle of Man, Northern Ireland, Scotland
GULF AREA:Saudi Arabia,Oman,Bahrain,United Arad Emirater,Qatar,Kuwait
OTHER MAP:America, Canada, Australia, Turkey, Russia, Brazil, Argentina, Chile are available
Menu Language& Navigation Voice: Arabic, English, Dutch, French, German, Italian, Portuguese, Spanish, Russian
GPS Features:
Power specification:DC-12V
Working current:<300MA
Standby state current:0MA
Working temperature: -20°~+70°
Operation system:Windows CE 5.0
CPU:Intel PXA255 Processor,Max.main frequency 400MHZ.
SDRAM/FLASH:1GB/64 MB
time of hot boot is 19S
Orientation presicion:<15m
Refurbish frequency:1HZ
GPS antenna frequency:1575.52MHZ
Length of antenna:5M
Voice indication:Intellectualized voice indication function
Display output:CVBS+S-VIDEO output(Resolution:800*480) or simulation RGB output
Audio output:Stereo output of CD tone.
Support:SD card
Resolution:800*480
Control way:Support touch control and Remote control
