Opel Zafira C Tourer => (C Tourer) General => Mensaje iniciado por: Luitorr en 30 de Junio de 2016, 00:39:00 am
(https://uploads.tapatalk-cdn.com/20170131/eb27a453040fdc2a8c2562325e6eee16.jpg)
(https://uploads.tapatalk-cdn.com/20170720/295c7647ac545e4d4dea263596285b2b.jpg)
(https://uploads.tapatalk-cdn.com/20170720/9a70901828fe27f53e7c3baa6da65b86.jpg)
(https://uploads.tapatalk-cdn.com/20170720/38c3c675d5b564a0e04ff44242bf853d.jpg)
(http://uploads.tapatalk-cdn.com/20160629/16a8e5a341882bf532e0f04bacd3ebb8.jpg)
(https://uploads.tapatalk-cdn.com/20170131/009a00741ba43473e34b4bad9016cae2.jpg)
(https://uploads.tapatalk-cdn.com/20170312/af882cd9c42262d4a5025dc74e72ead1.jpg)
(https://uploads.tapatalk-cdn.com/20170114/6325ff2fb08d6fb0fbdb44e253193269.jpg)
(https://uploads.tapatalk-cdn.com/20170115/e13e94ee477f547e155ad6d80fb824f0.jpg)
(https://uploads.tapatalk-cdn.com/20170115/0764360f67eed10d6a91923fd849ac4f.jpg)
(https://uploads.tapatalk-cdn.com/20170715/ebf89d9907918c95e5ed4f4413117401.jpg)
(https://uploads.tapatalk-cdn.com/20170125/86fed0e95683f732f503f575306d49a4.jpg)
(http://uploads.tapatalk-cdn.com/20160629/728b5ba60b4cdc3e3f4a3f608fb1f1a5.jpg)
(http://uploads.tapatalk-cdn.com/20161106/adccb05c8f8858a3581c2c7dc47c2d2e.jpg)
(http://uploads.tapatalk-cdn.com/20160629/c8b94cfce14327c180b9446d42bc294c.jpg)
(https://uploads.tapatalk-cdn.com/20170925/7c8d6d64fb5eb966b04ed0c80b2f9ef4.jpg)
(https://uploads.tapatalk-cdn.com/20170925/fda267318507c097cfb63eb25f9f4ed6.jpg)
(http://uploads.tapatalk-cdn.com/20161126/1f01ff502f781aac2035851ada5d41d4.jpg)
(http://uploads.tapatalk-cdn.com/20161227/c925cfbb85db0274368da13f239fd186.jpg)
(https://uploads.tapatalk-cdn.com/20170408/18d97727afcce59fec62f4dae16c93f4.jpg)
(https://uploads.tapatalk-cdn.com/20170715/6bf683df9e720d1c681171a0906954f8.jpg)
(http://uploads.tapatalk-cdn.com/20160808/b3421657c9a5cc4ba8111f2a6ff6b9e3.jpg)
(http://uploads.tapatalk-cdn.com/20160629/67eeb42bd46ad44ef277c9611289f39e.jpg)
(http://uploads.tapatalk-cdn.com/20160629/187e1bf4365a8956d9f0056daa5f61d9.jpg)
(http://uploads.tapatalk-cdn.com/20160824/0a9554a3a5d1b91a4a9673a74baec7ca.jpg)
(http://uploads.tapatalk-cdn.com/20160829/3a79ef49b551a56ff8ba86d8b3150f04.jpg)
(http://uploads.tapatalk-cdn.com/20161126/888716f826fe61eeeab36d748ab02a6e.jpg)
(https://uploads.tapatalk-cdn.com/20170312/761a2ef13d5778535261a460f950b0e9.jpg)
* Espero que os guste , ya iré añadiendo alguna más !!
Muy chulo luitorr, por cierto tu que estas puesto mucho en la materia de la zafira sabes si es normal que en el capo del coche por la parte interna tenga gotas de agua secas,sera que me entra agua.o al darme el coche limpiaron y quedaria gotitas.lo siento por preguntar en tu post.
No pasa nada , si es normal que entre agua tanto en el capo , como por los umbrales de las puertas y del maletero , tampoco es que entre el agua a chorros ... pero sí cuando la vayas a limpiar a la Tourer tendrás que secar esas partes que te comento por que siempre entra algo de agua , pero no solo en nuestras Zafiras si no en todos los coches y marcas , ya hay algún hilo abierto de este mismo tema .
Saludos .
Respesto al coche se esta quedando muy bien,yo que soy un manazas no hago esas cosas jeje y respesto a las gotas,si wue entra agua en el motor,yo en mi antiguo coche que era un leon no entraba nada,lo digo por que cada vez que lo lavo habro el capo para quitarle el polvo por encima y no se acumule y a la opel le entra agua. Y al otro nada de nada,yo para mi no me gusta que entre agua en el motor no es de mi agrado,en la opel resvala el agua y donde esta el tapon del aceite se forma hasta un charquito,como para dejarte el tapon un poco abierto se va el coche a la ***,espero que estando bien cerrado no entre nada.
Enviado desde mi LG-H815 mediante Tapatalk
Muy chula te está quedando, para activar el otro antiniebla fue *** o sólo enganchar un cable?
Al final instalación de cableado nueva al antiniebla derecho , relé , fusible de 10A , módulo para conectar todo esto , grapas , terminales , conector de origen , antiniebla original derecho con su portalámparas y bombilla , desmontar paragolpes trasero ... vamos para entretenerse unas horas !!
*Lo fácil hubiera sido una instalación en paralelo como hicieron algunos compañeros y a funcionar sin problemas , pero a mi se me apagaba con el motor encendido a los 2 segundos por sobre consumo y probé otras opciones que no dieron resultado .
Pues vaya me parece que no toca por lo menos hasta que se acabe la garantía jajajja
Eres un crack Luitorr.
Yo también me he fijado que hace poza en la toma del aceite cuando lavas el coche. Mi experiencia en otros coches es que si que les entra agua, pero no había visto esa poza en ninguno.
Por otra parte y abusando de Luitorr, para colocar los plafones led: 1, quitar los de serie apretando hacia dentro con una pestaña y salen no??, 2, quitar conector de serie y poner el nuevo que se supone es igual?? Y 3, colocar los plafones en su sitio y ajustarlos bien?? No se si me dejo algo o hay que matizar algún punto. ºWº por adelantado.
*** que follon,no me entero de nada de lo que decis,jeje,a mi esas cosas no se me dan bien y me gustaria hacerlas,yo cuando lo lleve a la revisión se lo comentare y si no sale caro que me lo hagan los de opel.
@rub123 , en el punto 1y 2 los plafones de origen salen casi solos , tienes que hacer la presión en la pestaña hacia el lateral y tirar hacia abajo e lateral el plafón para que salga del hueco .
Una vez fuera desconecta su conector y el nuevo plafón de led debe llevar un cancelador para conectar para que no te de fallo de Can bus y ahora ya puedes conectarte el conector de origen , (muy importante lo del cancelador ).
Y el 3 punto y último es colocar los plafones de led en su posición de origen y muy a tener en cuenta por que te puedes cargar las pestañas y si tiene algo de juego la base interior por que es más estrecha que el hueco y no te ajusta bien ... tranquilo que ya te doy una solución que te quedará bien ajustados .
Perdona por el tocho ... [emoji2]
(http://uploads.tapatalk-cdn.com/20160630/a99426ffb5d27f1b9ce6f3fb528e51d6.jpg)
(http://uploads.tapatalk-cdn.com/20160630/0a81ecf689c1dfb56c79f1e66fddaa01.jpg)
Yo acabo de poner hoy las luces LED de matrícula y es facilísimo, sólo tira de ella del lateral que está un poco salido y sale casi sin hacer fuerza y para meterla lo mismo, tranquilo que no la partirá a mi nada raro
Que has puesto bombillas de led o los plafones de led ?
Buen trabajo luitorr , eres un artista , yo intenté montar leds de intermitencia pero ningún modelo vale , todos piden conectar una resistencia para el tema consumo ,
Gracias @CarlosYeles , lo tenia claro desde que me la entregaron que quería el doble antiniebla para mi ZT .
Eso no se me había pasado por la cabeza lo de los leds de intermitencia , pero todo es ponerse ... jejeje .
Ahora tengo un par de cosas más en proyecto , pero nada de electrónica de momento ... quiero disfrutar de mi ZT y del verano , observare el funcionamiento de todos los bricos realizados hasta el momento por el tema de la garantía oficial .
Saludos .
He puesto los plafones de LED enteros, como los que has enseñado tu la foto
O.k , quedan muy bonitos estos plafones , la verdad !
Si, tengo en cuenta lo del can bus para que no den fallo. Me voy de vacaciones la semana que viene así que hasta finales de julio no retomare el tema. Como soy poco hábil con estas cosas me da miedo lo que has dicho Luitorr, romper alguna pestaña o algo. Una pregunta, el cable tiene sitio por dentro para que este replegado??
Por cierto, he pasado por el concesionario esta tarde para lo de la tapa marrón para la toma del maletero y en principio me dicen que no, que sólo lo hay negro. Yo le insisto porque no me parece normal y me dice que le de el bastidor y mira el despiece de mi coche, entonces si que aparece, en negro y en marrón. Así que se queda aparcado eso también de momento hasta que vuelva de vacaciones.
Otra pregunta, aunque ya creo que la he hecho en alguna ocasión, ni afecta para la visión de la cámara trasera? Se ve igual, mejor, peor...?? Si alguien tuviese una zafira caoba como la mía o en algún color oscuro podía poner una foto de como quedan los leds en la matrícula.
Por cierto Luitorr, para mi tus "tochos" son muy constructivos.
Si , tiene sitio para el cancelador , puedes dejarlo como viene .
La mía al ser el blanco alpino no noto que se vea peor que con las de origen , pero no te se decir si puede variar con el color caoba , cuando tengas que ir a comprarlos ... se lo comentas si admiten devoluciones por si no son de tu agrado , que lo dudo !!
Eso si los que llevo yo son de 18 leds cada plafón , y te digo que hacen luz .
* Gracias rub123 por el alago!
Guay, Luitorr. O0 O0 O0
Gracias SrLander !
¿Los pedales metálicos son originales Opel?
Si , los opc !!
ahora que me fijo, ¿le quitaste las letras de ecoflex?
yo tengo que quitar unas que me han puesto de publicidad del concesionario debajo de zafira ||O ||O. no me di cuenta al recogerla
y tambien en la matricula trasera. espero poder quitar todos los rastros de publicidad sin dificultad
Hola Rivik48 , así es le quite las letras de ecoflex y le deje las de Zafira Tourer ...aún con dudas si se las quito o le dejó sólo lo de Tourer .
Las letras se quitan fácil y los restos con alcohol se va bien ... no quedan marcas !!
Lo puedes hacer de muchas maneras , por ejemplo: con un poco de hilo de pescar sobre la almohadillas que llevan las letras pegada , con un secador dándole calor para que vaya despegando e incluso con las manos también te salen pero cuesta un poco más y te dejas las uñas hasta que empiezan a despegar ... de esta última manera las quite yo de mi Astra H anterior !!
Luitorr la segunda foto, la de la llave en el encendido. ¿Que has puesto, una pegatina circular?
Jajajaja, una pegatinaaaa ?[emoji23] [emoji23] [emoji24]
(http://uploads.tapatalk-cdn.com/20160713/beb4036731af55ee923fcedf1f365804.jpg)
(http://uploads.tapatalk-cdn.com/20160713/5a9c633c62521c9337892940084487ed.jpg)
*Yo le puse este acabado por las luces de cortesía y así guardar la estética interior de mi ZT .
jajajaja, queda chula, link o algo, no?
Encima hay varios acabados de color .... mmnnnnnn !!!
Ahí lo tenéis , donde comprarlo !
Ignición del coche interruptor de la cubierta del coche auto accesorios para Chevrolet Cruze Malibu Aveo Trax / Opel Mokka ASTRA J Insignia Zafira Vectra
http://s.aliexpress.com/NBb2IJv6
(from AliExpress Android)
Gracias!
[emoji106] [emoji6]
Hala, a gastar... jajajajaja. Me la he pillado en rojo también, creo que quedará mejor.
Parece que por la noche se ilumina.
[emoji106] [emoji6] [emoji2]
Chicos yo puse hoy los plafones de matrícula y madre como iluminan!!! Ahí van unas fotos [emoji12].....
(http://uploads.tapatalk-cdn.com/20160802/8b87f1ab6a19b00127bafab4f0e3e6ac.jpg)
(http://uploads.tapatalk-cdn.com/20160802/121de954515874006072b2c42e057da2.jpg)
(http://uploads.tapatalk-cdn.com/20160802/c7d3301b6b817d59e7883ca1eddbd53a.jpg)
(http://uploads.tapatalk-cdn.com/20160802/63d09586937d4b7011d4b43d25f5d8ad.jpg)
Buena compra compañero !
Me alegro que te gusten como quedan , para mi gusto ... im - presionante !!!!
Muy chula Luitorr esa zafi con esos detalles <love <love por cierto en mi B también llevo unas H7 en la matrícula de led >:D que alumbran de muerte SoO ee
Gracias @Adrilore !!
Me alegro que te guste , la verdad que poco a poco me la voy dejando un poco más bonita ... ahora estoy con 2 o 3 cosillas más que para finales de Agosto añadiré las fotos con los detalles de lo realizado !!
Yo también puse los plafones led en la matrícula, a ver si me acuerdo y comparto unas fotejas.
La bandeja con las letras de Zafira en el maletero también me la pillé pero pensaba que sería más rígida, la veo algo enclenque.
Lo del segundo antiniebla trasero está chulo pero creo que nunca he usado el antiniebla trasero en ningún coche mío... Por Madrid no suele hacer falta. Alguna vez camino de Algete pero vamos que poco uso le doy.
A la espera de esas novedades de finales de agosto...[emoji1]
Pues eso hasta finales de agosto no hay fotos ...jejeje que luego os copiáis , jajajajaja [emoji6]
Por cierto Luitorr la tuya esta canela, canela ya te lo dije alguna vez [emoji12] [emoji106] .
Ayer la mujer rasco la nuestra [emoji26] [emoji26] [emoji26] poca cosa pero canta con pulimento sale.....menos mal
Pillaban, donde las has comprado y que te han costado si no es indiscrecion?? Las has puesto tu? Imagino que no te han dado el fallo con el can bus. Yo es lo proximo, y cercano ademas.
Audioledcar. El precio es si no me equivoco 29€ y fallo no me han dado o yo no he visto que saltase fallo alguno [emoji12]. Las puse yo es muy fácil de hacer la verdad
Gracias @Pillaban22 por el cumplido !!
Joer , estas cosas nos puede ocurrir a todos ... a mi me marcaron con el tornillo de la matrícula de algún coche , por que tengo un par de marquitas en el paragolpes trasero ,[emoji24]
Sí el problema es que se fue a la playa y le bloquearon la salida y que se le ocurre? Ponerse a maniobrar hasta que claro roza contra la defensa de un furgón desde la aleta trasera hasta casi la puerta tiene todo el plástico negro de la defensa del furgón. El problema que creo que se levantó la pintura [emoji26] [emoji26] en lugar de esperar y llamara la policía......pero bueno cualquier día puedo dar yo es así [emoji47]
Ufff , me a dolido hasta mi compañero como lo has relatado ... No entiendo a la gente que aparca y no guarda las distancia obligatorias , nos gastamos la pasta en sensores de aparcamiento , cámara y mil historias para que luego llegue el ....... de turno y te lo aparque bien pegadito para que no puedas salir[emoji35]
A esto del aparcamiento estoy completamente deacuerdo. Además, nosotros podemos tener todo el cuidado del mundo pero los demás...... Muchas veces pasan y nos dan toques o roces que..... <mazo
Pillaban, muchas gracias. Audioledcar ya lo tenía yo mirado, además me pasaría por sus oficinas para comprarlas, no me gusta hacer estas cosas por Internet.
Si te funcionan bien pues eso me anima todavía más a ponerlas, y el precio lo que creía, 29 euros.
ºWº
Deseando ver esas novedades Luitorr!
Jejejeje, pues ya tengo dos novedades nuevas para presentar ... Bueno 3 , pero me queda otro brico que es el más esperado por mi y mi Tourer !!
Este será para las vacaciones , que tendré más tiempo para ver opciones .
Cómo te gusta ponernos los dientes largos...
Venga os voy a poner un adelanto de uno de ellos ...
(http://uploads.tapatalk-cdn.com/20160805/57ac704007ede797cb532eb0ea2aeec5.jpg)
Ay... Pájaro, no dan demasiada luz? Yo creo que cambiaré solo las del maletero.
Teniendo en cuenta que están todas encendidas del interior y que son led de 7500 k ... quedan impresionante al natural cuando le das al botón de abrir el coche , menudo cambio a premium a dado la Tourer !!
Estaba hasta los ........ de la poca luz atenuada que dan las de origen !!!!!!
Vamos digo lo mismo que dije con las led de los plafones de la matrícula en dos palabras IM - PRESIONANTE [emoji6] [emoji106]
Ostrasss que chulada!!!!
Yo también lo quiero!!!!!
¿Donde has comprado esas luces led, tanto las de interior como las de posición?, ¿Que precio tienen?, ¿Son fáciles de colocar?.
Un saludo y buen finde a todos!!!
Si tengo tiempo , intentaré preparar un brico para las luces led interior del ZT ...
Las luces de led de los plafones de la matrícula están más arriba del hilo y hay varios compañeros que también han puesto el link de donde lo compraron , yo las compre en Amazon , de precio me salieron por 18€ !!
(http://uploads.tapatalk-cdn.com/20160806/83f9bd9406353398e44303389544a83b.jpg)
(http://uploads.tapatalk-cdn.com/20160806/39d59eb338c6d9e067c8b3d8558fca19.jpg)
Las luces de led para el interior del ZT las compre por eBay , precio 34,80€ !!
(http://uploads.tapatalk-cdn.com/20160805/20459a09373ea93481e20ea7bc1fdc65.jpg)
Ya sólo te queda poner las led blancas en las luces de marcha atrás...
Pues has acertado , estoy barajando esa posibilidad ... Tu las tienes para ver cómo quedan ?
No, sólo tengo las de la matrícula, pero me animaría a cambiar las de interior y las de marcha atrás.
O.k @binamo , a ver si algún compañero que las tenga puesta los led de marcha atrás para ver cómo quedan y así despejar las dudas posibles ...[emoji106]
Aquí tenéis información de los led de marcha atrás, yo las compre también en el enlace que sale
http://www.clubzafira.com/index.php?topic=65264.msg905521.msg#905521
Enviado desde mi Nexus 4 mediante Tapatalk
Hola montegro ,
Muchas gracias por la información y por poner el hilo [emoji106] [emoji6]
*Voy al lío !!
Aquí alguna foto más, sabia que había un hilo con mas detalles
http://www.clubzafira.com/index.php?topic=56979.msg918755.msg#918755
Yo las tengo puestas desde entonces, la verdad es que no se la fecha en concreto pero ningún fallo y en garaje mejor que las originales
http://dxcatalog.net/en/sku-233918/exled-t15-45w-400lm-15-x-smd-5050-led-1-led-white-light-car-backup-light-12v-pair#.V6h-kBkhXqA
¿Estas sirven?
Enviado desde mi MotoG3 mediante Tapatalk
Luitorr, una pregunta
He mirado los LED en ebay y pone que se compone de 8 luces. Imagino que viene para todo el coche excepto los parabrisas, ¿es así?
¿Son difícil de poner? No soy nada manitas
¿Estas sirven?
Aparentemente y mirando especificaciones son las mismas
Duplicado
Es un falso enlace a las que estaban puestas en el post que has enlazado. Están agotadas en todos los sitios que he buscado.
@binamo , aún no he mirado nada con decisión final para comprar las led de marcha atrás , ando un poco liado ...
@Rivik48 , si el Kit incluyen 8 led para las ZT con techo panorámico por eso son algo más baratas que el Kit que incluyen 12 led para las ZT sin techo panorámico ...
Sobre su instalación no es difícil , no llegó a la hora hacerlo ... eso si con precaución y delicadeza para no romper ninguna pestaña , que es mi Tourer!! [emoji6]
Me animé a poner las led de la matrícula... Muy fáciles de poner y resultado espectacular.
(http://uploads.tapatalk-cdn.com/20160816/699762f8a9b322844c5d9a4694c2b78d.jpg)
Joer , como quedan los plafones de led compañero !![emoji6] [emoji106]
Yo en breve los pondré también, a ver si de la semana que viene no pasa.
Has visto @Rub123 como quedan los leds interiores para la Tourer ?
(http://uploads.tapatalk-cdn.com/20160816/fa3d7f4c9b1a5eb0932a26152655cd80.jpg)
Jejeje , se te va acumular el trabajo compañero ...[emoji6] [emoji106]
Buen trabajo esta tourer k vais estrenando!!
Para mi el led interior, matricula y marcha atras fundamental!!!
2 añitos llevan las mias de marcha atras y de momento perfectas siguen y eso k las tengo puestas para k se enciendan al abrir y cerrar el coche...
@bilbosport llevo varias en seguimiento pero no tengo claro cuál poner aún , aunque si dices que el modelo de bombilla LED que llevas tiene ya 2 años es interesante y a tener en cuenta !!
@luitorr sobre todo fijate k la bombilla en si sea metalica no tenga capuchon de plastico.
Creo k le da mejores acabados y evita k se derrita x calor aunk en marcha atras seria dificil eso en la diurnas por ej ha habido casos ya por aqui...
Cuando dices que lleve el capuchón de plástico , es a la bombilla que lleva cob + led en los laterales , no ?
(http://uploads.tapatalk-cdn.com/20160817/5511e03c41a7a281b1876c9b06b418ac.jpg)
Podrías poner las que llevas tú o si me recomiendas unas tu personalmente ?
Gracias !!
(http://uploads.tapatalk-cdn.com/20160817/23a0c6a77bca839729d78f3463f52357.jpg)
Queda de lujo <love <love
Gracias @Adrilore , no es por repetirme pero en la foto no se llega apreciar realmente como queda ... como al natural , yo estaría dándole al botón de apertura del mando todo el día , es una de las cosas que más me han gustado de todo lo que le hice a la Tourer .
Bueno el que tengo pendiente también me gustará mucho cuando lo acabe y que tú bien sabes , [emoji6]
T_T AmmA [plas] <love
@luitorr me refiero k dnd enganchan sean metal no plastico. Son de mayor calidad.
Son estas k aunque estan agotadas te haces idea de caracteristica y aspecto...(http://uploads.tapatalk-cdn.com/20160817/5e34cab985ae25bfaa966474821b0b1b.jpg)
(http://uploads.tapatalk-cdn.com/20160817/8a3c70b37eea2441c1342ccfc319e2a0.jpg)
Como habías dicho lo del capuchón de plástico , entendí el aro de plástico que lleva la bombilla por eso puse las 2 fotos de las bombillas led + cob , gracias por la recomendación @bilbosport !!
Una cosa has visto la 1era foto donde se ve los tipo de smd led con consumos diferentes y las mejoras ?
La verdad k la luz buena la da el led grande.
Si , la bombilla con el smd 3535 hablan muy bien de luz brillante y con más lumen que la smd 5050 , pero como muchos del club tenéis este modelo y os a ido bien ... Esa es mi duda compañero !!
Los led para la matrícula esta más que decidido, lo de los led interiores........ No lo tengo tan claro. Es simplemente cuestión de gustos. A mi para el interior me gusta una luz cálida, o sea, la que tiene, me da sensación mas agradable que todo tan blanco. En cambio si que echo de menos más luz para el maletero, pero eso ya será arena de otro costal.
El led para la marcha atrás juraría haber leído en el manual de instrucciones que ya es de led......... No se, lo juraría, pero seguro que estoy equivocado y no lo es. La cuestión es, se nota tanto ese led en la marcha atrás como para que sea tan recomendable ponerlo??
Con permiso de los compañeros y propietarios de la Zafira Tourer te voy a poner unas foto para que lo veas ... Si hubiera que quitarla que lo haga algún moderador o me lo avisen para quitarlas ....
(http://uploads.tapatalk-cdn.com/20160818/d1239fcf5e4bfaf40fdb217badf5296e.jpg)
Así me quedaría a mi al ser en blanca como la mía !!
(http://uploads.tapatalk-cdn.com/20160818/997883a98db47b7bb6c9a0bbac040c57.jpg)
(http://uploads.tapatalk-cdn.com/20160818/88b8935a2d12b48d8313798381c11a6b.jpg)
Así te quedaría a ti Rub123 al ser oscura de color , tu mismo saldrá de dudas !!
Esa foto es mi zafira (la blanca)
Tranquilo k no pasa nada por ponerla.
@rub123 Pues yo entro de culo a la parcela y veo mucho mejor por la camara la verdad.
Para k te hagas idea se las puse a mi padre en su bmw y ahora mete el coche de culo en su parcela cerrada sin tener k bajarse a dar la luz cosa k antes no podia.
Gracias @bilbosport , le tape la matrícula por si acaso ... Si anda que no cambia con la luz de marcha atrás con led blanca , más bonito estéticamente y la ventaja de mejor iluminación por la noche para hacer las maniobras !!
Vaaaaaaaaaale, me habéis convencido. Primero ataco a los plafones led, y aprovecharé el viaje a la tienda y preguntaré por lo de marcha atrás, que no den fallo y esas cosas.
Se ponen fácil????? Os repito que soy muy torpe y me da miedo tocar cosas originales del coche por si se estropea algo.
En el magentis le puse xenón (del no legal) y aunque era can bus y todo lo que quieras pero me volvió loco a la centralita del coche.
Fácil no lo siguiente ... solo tienes que quitar las tapas del portón del compartimiento de carga y girar el portalámparas media vuelta ,cambiar la bombilla a led y volver a poner todo como estaba compañero !
(http://uploads.tapatalk-cdn.com/20160818/048b0c6ceac1c877a7236a2f91069a63.jpg)
(http://uploads.tapatalk-cdn.com/20160818/f06407c8c8ba151fbc7a49e57702bfda.jpg)
(http://uploads.tapatalk-cdn.com/20160824/8c3783a0bca2e06eceae431f8072be12.jpg)
Ok ºWº
Yo he puesto plafones tambien y queda de lujo
(http://uploads.tapatalk-cdn.com/20160903/287c0b456da98051ea2f14867e0a51a8.jpg)
Así es , no entiendo como no lo instalan de origen ... como si lo hacen en otras marcas ya en casi toda la iluminación del vehículo !!
No doy con unas de marcha atrás para comprar...
Compañero @binamo mira que sea w16w = T15 y las que llevan de origen son 18W con esos datos ya lo que quieras poner ...(http://uploads.tapatalk-cdn.com/20160903/0a923186b3c051522ca7555919f9319d.jpg)
(http://uploads.tapatalk-cdn.com/20160903/0d9dc48d28b7bd2015059f8223869d39.jpg)
Ya vi que cambiaste la de marcha atrás y las del habitáculo. Si la mujer lo viera a lo mejor se decidía. Tenías fotos pero no las localizó.
Enviado desde mi SM-J320FN mediante Tapatalk
Mira el principio de este hilo ...
Empecé hoy con el tapatalk y voy loco. Gracis
Lógico , ahora toca familizarse con el foro y la app ... no te preocupes estamos para ayudar en todo lo que se pueda !!
Bueno, ya he cambiado la tapa de la toma del mechero del maletero a marrón, no la negra que tenía, para ya dejarlo perfecto. Y esta mañana he ido a comprar los plafones led... quería haberlos puesto esta tarde pero al final por otras cosas no he podido. Mañana por la mañana espero poder instalarlos. Cuando los tenga instalados pondré alguna foto de las dos cosas.
Venga Rub123 que te veo animado y con ganas ....[emoji6] [emoji106]
Ya las tengo puestas, quedan bien y no dan fallo. Hasta ahí bien, pero hay una cosa que no me gusta, y es que aunque encajan bien queda holgura, tanto lateral como en profundidad, por lo que eso no va a ser hermético en la vida.
Os pasa también a vosotros??
He pensado en reforzar la goma lateral para que encaje bien, no se mueva y sea hermético. La otra opción devolverlos y comprar solo las bombillas led.
Así es Rub123 , ya te lo dije en algunos de los post del hilo , que cuando las pusieras ... Si no te quedaban ajustadas que preguntaras , y es lo que has hecho ....
Si a mi me paso igual son un poco más pequeñas la base y por eso no se ajustan bien , yo lo solucione con cinta gomada que se pone debajo de las vitrocerámicas que va pegada al mármol y así se quedan como las de origen sin movimiento ninguno !!!!
Te pongo una imagen para que veas lo que te digo ....
(http://uploads.tapatalk-cdn.com/20160906/4077b0e87ecfc26f08af6c66e1d061df.jpg)
Eso mismo había pensado yo!!!, esa tiras de la vitrocerámicas que van por dentro. Como trabajo en esas cosas esta tarde me hago con esas tiras gomadas y mañana los quito y se lo pongo para ajustarlos bien.
De nuevo..... ºWº
De un trozo lo cortas por la mitad y te da la medida para ponérselo y se quedan super ajustados , ya lo verás !!
Ok, imagino que no pasará nada por haberlos dejado ya puestos. No creo que entre mucha suciedad entre hoy y mañana. Mañana por la mañana me pongo en fase "ajustes".
No te preocupes , que no entra nada ...lo único que no ajustan bien , nada más !!!
Caray! Te las sabes todas
Yo yo .... [emoji2] [emoji6] [emoji106]
Bueno, ya está terminado y ajustado. Parece que ha quedado bien, no se mueve ni tiene holguras. Esta noche si puedo pongo alguna foto de los resultados.
Me estáis poniendo los dientes largos con lo de los plafones para la matricula,ya había pensado cambiar las lámparas por unas de led,pero me mola más lo del plafon,cuando tenga tiempo me pongo a mirarlo.
Por cierto,para la marcha atrás,sabéis si hay lámparas de led que emitan pitido?
Bueno me acabo de pillar estas a ver que tal resultado dan. [emoji16] [emoji16] [emoji16]
(http://uploads.tapatalk-cdn.com/20160907/a3acc48a48af1ce4ad97dc26307bbdf3.jpg)
Ya tienes otro acabado @Rub123 , vas cogiendo el gustillo hacerle tus cosillas a la Tourer !!!!
Esas bombillas led para la luz de marcha atrás te van a quedar de lujo @Pillaban22 , ya lo verás ... Ese modelo las tienen puesta muchos compañeros y están encantados después del paso de tiempo !!!
@Tony ni idea de su existencia , pero molaría mucho ahora que vamos cara la Navidad que en vez de pitidos suene la música de villancicos ....[emoji6] [emoji106]
Luitorr,yo con que haga Pi,Pi,Pi,ya me conformaba.
En mi todoterreno llevo una lámpara que venía con el zumbador incluido y la verdad es que viene bien cuando estás dando marcha atrás y pasa algún despistado,lo que pasa que debe haber más de un sordo por que alguno ni con pitido se entera.
Ya lo preguntaré cuando mire lo de los plafones.
Jajajajaja , joer que era una pequeña broma ... No está mal la idea la verdad , ni se me había pasado por la cabeza lo de la bombilla con zumbador , ya dirás algo si las encuentras y precio !!
Ya me lo imaginaba,pero luego habrá alguno que quedra que suenen villancicos,ja ja ja
Si antes había de las normales debería haber ahora de led,otra cosa es que se puedan encontrar fácilmente.
Bueno hoy llegaron los leds no los esperaba hasta la semana pero..... me dieron una sorpresa jajajaja
(http://uploads.tapatalk-cdn.com/20160909/ad3559d3c80a8e40f1594636c69db88a.jpg)
(http://uploads.tapatalk-cdn.com/20160909/3c79a2cc52a4075b89e99287da39a9f6.jpg)
(http://uploads.tapatalk-cdn.com/20160909/d99c28593babb916b52924bd8c2e5b77.jpg)
(http://uploads.tapatalk-cdn.com/20160909/f611c25dcf27f169d96cde449ad1589e.jpg)
(http://uploads.tapatalk-cdn.com/20160909/e1f688ca9dfd73bd3e38c567d086febf.jpg)
Muy guapa,si señor.Yo ya estoy mirando los plafones para la matrícula y ya he visto que si que hay luces de marcha atrás con pitido,sólo queda buscar una t15,si no me equivoco,con zumbador y otra igual pero sin zumbador o, dependiendo del precio, las dos con pitido[emoji14] [emoji14]
Yeahhhhh , de noche encendida te gustará más compañero !!
Poco a poco os vais dejando la Tourer más bonita ....[emoji6]
¿de dónde son y precio?
EBay y fueron la unidad 6€ fue lo mejor que encontré de precio por ebay. Pero seguro que aparece algún vendedor más económico los había de japón, USA, etc yo preferí cogerlos en Francia por tema de aranceles jajajaja
¿tienes enlace?
Es que quedan de lujo las leds ...
(http://uploads.tapatalk-cdn.com/20160909/42589ee3fe376f71371aa7853f92fdcf.jpg)
*Como a cambiando la trasera de mi Tourer [emoji6]
Yo probaré estas a ver que tal
(http://uploads.tapatalk-cdn.com/20160909/502162882ea15f58b5ebc8bdd4605bfe.jpg)
La verdad es que quedan muy bien. O0
Yo creo que me voy a animar..es un coste razonable y ganas consumo (testimonial) y visibilidad.
Pedidas las de chuchimon
Yo también binario. Le *** el móvil a la mujer y las pedí. Que luego me vino diciendo que si había comprado no se que con su tarjeta.... pero ya le dije lo ridículo del precio. Todo para acceder mi mujer no le hace gracia comprar por Internet, pero para estas cosas cada vez es imprescindible por la cantidad de precios y productos.
Gracias al los que vais por delante haciéndonos más fácil el camino para dejar bien rebonicas nuestras zafiras.[emoji7]
(http://uploads.tapatalk-cdn.com/20160910/d46694f9d0367760ac1690a7860ff53d.jpg)(http://uploads.tapatalk-cdn.com/20160910/a7c8821e17aa49fe55b54481ff835257.jpg)(http://uploads.tapatalk-cdn.com/20160910/50d1c2646570e1f96469b4840f5547bb.jpg)(http://uploads.tapatalk-cdn.com/20160910/cb22de8866d1aa2efabf06a276b3bd97.jpg)(http://uploads.tapatalk-cdn.com/20160910/828df054cb7b38edb98bc166c2dfc9d4.jpg)
Que no te se olvide poner la placa V-20 no sea que vayas a tener un percance con los de verdes !!!?
(http://uploads.tapatalk-cdn.com/20160910/5655f128ebcde193370e109e9bad67a6.jpg)
(http://uploads.tapatalk-cdn.com/20160910/e48da95bc7bf64740da9c490683be339.jpg)
Yo también binario. Le cojí el móvil a la mujer y las pedí. Que luego me vino diciendo que si había comprado no se que con su tarjeta.... pero ya le dije lo ridículo del precio. Todo porque a mi mujer no le hace gracia comprar por Internet, pero para estas cosas cada vez es más imprescindible por la cantidad de precios y productos.
Gracias al los que vais por delante haciéndonos más fácil el camino para dejar bien rebonicas nuestras máquinas.
El caso es que la compré, pero como tenia entendido erróneamente que con el Flexfix no era obligatorio, me fui de Valencia a los pirineos pasando por Teruel paseando bicis con la V20 en el maletero.[emoji28] [emoji28] [emoji24]
Por cierto alguien ha pensado vinilar el zafira?
He estado rebuscando y buceando (mi familia ya no sabe quién soy) por páginas y páginas y no recuerdo haber visto nada al respecto de vinilos o "sprays vinilicos".
Muchas gracias
Mira esto en eBay http://www.ebay.es/itm/112006094963
Perdón por la tardanza en la respuesta [emoji26] [emoji26]
Hobbit que bonita la zafi,que voy a decir yo si es igual que la mia jeje.
Que se le va a hacer, tenemos buen gusto [emoji12]
Muy chula Hobbit...otra blanquita Excellence con flexfix, como la mía.
Y además veo que te atreves a meterte en pistas de alta montaña. Yo aun no lo he hecho..pero lo haré. Aunque me da un poco de miedo lo poco protegida que lleva los bajos.
Por cierto, otro que ha pedido los led de Chuchimon, a ver que tal quedan.
Por cierto ahora solo falta poner las antiniebla y he encontrado esto a ver que decís.............
Mira esto en eBay http://www.ebay.es/itm/131817521578
Ahí sí tengo más dudas. En dos años no he usado las antiniebla y quizá se deba a la brutal iluminación de los AFL, y encima veo que son casi 40€, creo que antes me hago el pack interior LED.
Enviado desde mi iPad utilizando Tapatalk
He de decir que los llevaba de corbata al principio, pero mirando el peso que pueden soportar (en teoría bicis eléctricas ) y como las llevo de aluminio, ya ni miro ni cuando te "comes" uno de esos socabones de autopista a 120km/h reales
Bueno, espero que a Luitorr no le moleste que le usurpe el post para poder poner alguna foto de mis mini bricos, los prometido es deuda:
(http://i64.tinypic.com/aeup78.jpg)
(http://i63.tinypic.com/317jz1d.jpg)
Y los plafones:
(http://i66.tinypic.com/1oop4n.jpg)
(http://i65.tinypic.com/dm60it.jpg)
IMG]http://i64.tinypic.com/9a6105.jpg[/IMG]
Y ajustados para que no se muevan y encajen perfectos:
(http://i63.tinypic.com/2lw7r6g.jpg)
(http://i64.tinypic.com/35lb5fp.jpg)
Quien tenga dudas que no las tenga. Las luces dan mucha más elegancia y la toma de mechero, nunca sobra.
No me importa compañero , ya has visto que en mi hilo se habla de todo y no he dicho naaaaaaaa !!
Cambiando de tema pero que rebrutooo que eres Rub123... jajajajaja , que has puesto la cinta engomada directa a la chapa , hmmmmm .... Hombre eso se pone en la base del plafón recortada y así no se ve nada y queda como de origen compañero !!!
* También decirte que me alegro personalmente que te hayas decido por hacer esos dos bricos y que estés contento con los resultados obtenidos ... Ahora lo siguiente las de marcha atrás , que eso lo tienes chupado !!!
Estube a punto de hacerlo así, se que hubiese quedado mejor pero me dio la paranoia de si entraba agua o algo por dentro y preferí asegurar, aunque fuese un poco a lo burro. Si lo ponía directamente al plafon era una tirita bastante fina lo que lo rodeaba y preferí asegurar, dado que aunque en las fotos lógicamente si se ve pero estéticamente sino te agachar y te fijas pues no se aprecia.
Si me da la vena lo quitaré y lo pondré como dices pero de momento yo creo que lo dejaré así.
Mira como queda como te digo ...
(http://uploads.tapatalk-cdn.com/20160911/1a3dd2bbb4916e58f8350752325ffdf1.jpg)
Ya, perfectos. No se los tuyos pero los míos es que el borde de alrededor eran muy finos, casi no había para poner el refuerzo de goma. Desde luego los tuyos han quedado de 10 y los míos..... Aceptables! Ya te digo, si me da la vena los quito y los trato de poner mejor. Hace un rato he salido a la calle y lo he mirado y si no te fijas mucho no se nota, aún agachandote. Lo que pasa con las fotos tan de cerca es que aprecia mucho, pero en realidad no es tanto.
Ya no lo toques Rub123 , ahora a disfrutar de la nueva imagen de la trasera de tu Zafira Tourer !!!
Bueno sobre el tema de los leds para la marcha atrás , yo puse este juego de bombillas led ...
(http://uploads.tapatalk-cdn.com/20160911/95721adda5a76703e5f38e3a73626422.jpg)
Y este es el resultado del cambio ...
(http://uploads.tapatalk-cdn.com/20160911/488410069cd7546138241e4bd93fda05.jpg)
Y este es el resultado con la cola de escape y la feria de luces de la Tourer !!!
(http://uploads.tapatalk-cdn.com/20160911/65eec09b1b345eb3a83488c0f1b5267b.jpg)
Te voy a empezar a coger envidia por lo de la cola de escape... >:D
Deja de restregarlo!!!!!!! Ja, ja, ja.... Que envidia!!
Lo de las luces marcha atrás ya veré, ese es otro capítulo.
Yo voy al acabar dejándola igual que Luitorr, menos mal que la matricula es distinta
Mira que le pongo la doble cola de escape ....[emoji2]
(http://uploads.tapatalk-cdn.com/20160912/f3c30eefdc786a2fa232058d58187f12.jpg)
Estaríamos ansiosos de ver ese brico.
Por cierto,en teoría tendrías que homologar esa peazo cola de escape,no?
En un principio la que he puesto yo , no ... pero la doble cola de escape ya sería otro tema !!
Eso te corta un poco eh,que si no ya estaria puesta
Pues no te voy a decir que no me gustaría , jejeje ... Pero eso ya lo haría bien cambiando el tramo final entero !!
Y ya puestos,con un Pack Opc
Bueno ese tema está pendiente Tony , y todo se andará ....[emoji6] [emoji106]
Yo también lo tengo pendiente,pendiente de que me toque la loteria
Jajajajaja , si tu comentaste que por tema de dinero no era ...que era más tema de homologación , jejejejeje
No,Yo dije que lo que me preocupaba era los 2000 euros que me pedían,que ya puestos en gastos lo de menos es la homologación,de hecho las ZT de fábrica no traen reflejado el pack.
Creo recordar que eras tú el que lo ponía como impedimento.
Pues lo que digo yo que se queda pendiente compañero ...
Mantednos informados.
Jajajajaja , se queda de momento como has visto en la foto con una cola de escape
Hombre,quien sabe,en el futuro.Yo de momento acabo de laminar los cristales y comprar unas llantas de 17 para el Astra h de mi mujer y tengo que cambiar la transmisión del 4x4,así que se me ha acabado el dinero para grandes antojos.Pero los plafones de la matrícula y las luces de marcha atrás de led caen seguro,tengo a un compañero mirandomelo en Internet,porque he preguntado en dos tiendas y no tenían nada de eso.Lo de que lleve pitido la marcha atrás no sé si será posible.
(http://uploads.tapatalk-cdn.com/20160912/8309ce249301fcc74d24abaa3fc2bb55.jpg)hola alguno le habeis puesto unas molduras de estas a las puertas,parece que se tienen que quedar bien y proteger.
Y con el faldón OPC...
Que guapo
Como es que una si se puede y dos hay que honologarlas?
Por cierto. Lo he reciclado de mi astral H. (http://uploads.tapatalk-cdn.com/20160912/79e4a774defa5c04e88bcd86f1a6d676.jpg)1
Por si no tenía bastantes guardatrastos[emoji28]
Algo de eso tb quisiera mirar
He mirado en mi Astra y no trae el portagafas,se me acumula el trabajo [emoji12] [emoji12]
Prefiero estás de origen ... aunque reconozco que las otras protegen más el paso del umbral de la puerta !!!
(http://uploads.tapatalk-cdn.com/20160912/9b92b54657cb77e1ef090db5f4f4c0cb.jpg)
Yo llevo las de origen, me acogi a ellas ante de los recortes.
Lo de la cola de escape no seamos avariciosos, yo creo que con una queda de lujo, dos ya va a ser pasarse, aunque como se le antoje a luitorr......
Lo de las gafas en el agarradero me gusta mucho, vi que antiguamente lo traian y ya no, y sino fuera caro yo si que lo pondria (si es que se puede).
Ayer vi en walapop unas llantas de 17 de doble radio preciosas....... Don dinero..... Las que salen en la portada del manual de instrucciones.
Bueno la k lio el amigo juan y servidor con los leds...
Veo k ha dado su fruto y son unas cuantas ya.
Yo ya llevo bastante tiempo tanto con plafones como con las de marcha atras y perfecto. Y eso k cada vez k abro o cierro el coche se me encienden...
Yo lo mire pero es incompatible con la rueda de repuesto...
Así es @bilbosport es totalmente incompatible , a no ser que quites todo el kit de la rueda de repuesto con lo que con lleva a tirar de un kit antipinchazo , la mía la dejo como está a falta de unas cosillas que tengo en mente ... que iré haciendo ya poco a poco , que la tengo 8 meses y no he parado de hacerle cosas !!
Solo 8 meses, pero si es otra zafira!
Tengo tb lista larga de bricos:
Salida mechero maletero
Luces blancas leds habitáculo
OPCOM
Happylightshow
Tiras rojas leds consola central
Tintado lunas
Baca
Fundas
Mesa plegable respaldo
Fulldip llantas
Creo que solo queda turboreactor y dados del espejo retrovisor
AAHHH y una habitación en una pensión para la parienta mecha de casa[emoji24] [emoji24] [emoji24] [emoji24]
Joer si no lo hubiesen retirado de la venta no se los motivos probablemente la hubiese comprado antes que la 1.4 turbo [emoji26] [emoji26] [emoji26] que bonita es la jodida
Eso me dice mi señora , que ya no es nueva la Tourer ....jjjjjj
Me lo regalaron al comprarlo y lo "reciclé"[emoji16]
Yo nunca lo usé en el Astra H , y para mi Tourer no vale al llevar techo panorámico ... no lleva el asa agarradera en la fila del conductor y acompañante !!!
* Veo que no te vas aburrir este invierno compañero , como le hagas todo lo que tienes apuntado en esa lista ...xd
Y cuanto valdrá eso de las gafas??
Mira esto en eBay http://www.ebay.co.uk/itm/310946951135
Querer, quiero. Poder....despacito y regateando a la parienta
Luitorr, me refiero al original. No se si lo habrá, a ver si esta tarde paso y lo pregunto en opel.
Ni idea Rub , como no pienso ponerlo ... jajajajaja !!!
He comprado el de eBay. A ver qué tal
Enviado desde mi Nexus 5 mediante Tapatalk
Con un 20% de descuento sale el original en 51 euros
Esta barato barato di mi tu ... Jajajajaja !!
Como se te a quedado la cara Rub cuando te han dicho el precio ?
Por que yo le hubiera dicho al de recambios ... "SOLO" póngame usted todos los que tenga , por favor !!!
De momento se va a quedar como esta, me lo pediré a los reyes magos.
Si lo llevaban los Astra H,siempre quedan los desguaces.
Mirar en milanuncios , los tenéis a montones y bastante más barato que nuevo ... por supuesto !!
(http://uploads.tapatalk-cdn.com/20160914/da8f411d03630fcc72bb885210999050.jpg)
(http://uploads.tapatalk-cdn.com/20160914/d55541f20f56129255d8ce9e02a1d6c4.jpg)
De noche se ve mucho mejor [emoji12] [emoji12] [emoji12]
Muy bonita la Zafira ... Jajajajaja !!
Mira que no estoy arrepentido de haber pillado el blanco, pero ese rojo...
Pillaban esa si que mola. Roja y con Flexfix. De mayor quiero una de esas [emoji7]
Jajajajaja a gracias chicos se intenta mejorar y dejarla cada vez un poco más guapa pero sin tunear mucho ehhhh.
Respecto al color pues el rojo es precioso pero también os digo que si la hubiese blanco perla la cogería también [emoji7] [emoji7] [emoji7] [emoji7] [emoji7] [emoji106] [emoji106] [emoji106] [emoji106]
Por cierto cambie las placas de matrícula que venían atornilladas por unas de metacrilato imaginaros cómo queda y pegadas nada de tornillos [emoji12] [emoji12] [emoji12] [emoji12]
Calla calla que ese es el color que quería yo para mi Tourer y al final se quedó en blanco alpino ...[emoji24] [emoji24]
Igualito que al mi!
Ni rojo, ni techo solar[emoji24]
Cómo pegaste las matrículas?
Bueno yo aún pude sacar el techo panorámico , que es una pasada !!!
Quería, gasolina, roja y techo solar
Cinta de doble cara concretamente con esta
(http://uploads.tapatalk-cdn.com/20160914/e9554ee61da0bfe8a9390f0104e3e16f.jpg)
A mi me hubiera gustado la biturbo,con pack Opc,techo y Xenón,pero mi presupuesto era de 20000 €, no de 30000 €.Eso sí,me la hubiera comprado en Blanca,ya que soy un incondicional de ese color.Todavia me acuerdo cuando me compré el Vectra,en el 2001 y no se llevaba el blanco,alguno llegó a decirme que parecía un taxi,pero bueno que os voy a decir yo,si de 5 coches que he comprado,4 eran blancos y el otro porque era de segunda mano y el precio estaba bien,pero el color no me gustaba nada.Si tenéis curiosidad por saber el color podéis mirar en "fotos de los coches que hemos tenido antes de la Zafira" y ver lo que hice para disimular ese color.
Muchas gracias!!
Yo también llevo las de metacrilato puestas de concesionario , pero atornillada .... En cuanto se hagan feas o se rajen por el orificio del tornillo , las cambiare yo personalmente , no me dio tiempo a decirle que me dejaran las matrículas en el maletero que yo me las pondría al recogerla en el concesionario ... Así que para el próximo juego de matrículas , se quedan pendientes !!
Yo igual, de metacrilato y atornilladas.
Yo las llevo pegadas sin tornillos y quedan de lujo
Bueno,otro que se apunta a cambiar los plafones de luz de matrícula,ya están pedidos y para la próxima semana llegarán.Me dejó un compañero uno para probar y que diferencia.
En cuanto a la luces LED de marcha atrás con pitido no habido suerte,pero sigo buscando.
Yo también les cambié las de marcha atrás
Es que se me ha antojado poner unas de led pero con pitido de advertencia y de momento no encuentro en t15,ya veremos lo que hago al final.
Yo a mis plafones de matrícula no les hice nada, quedan bien ajustados, la verdad, me hacéis dudar...
Enviado desde mi Mi-4c mediante Tapatalk
A ver lo que quiere decir Rub123 es que quedan con un poco de juego la base interior y por eso lo de poner esta cinta gomada para su ajuste como las de origen !!!
(http://uploads.tapatalk-cdn.com/20160920/2e7c61dd0205c6fabc7416b60936ae7e.jpg)
Que guapos quedan estos plafones.Me los ha dado, el compañero,a la salida del trabajo y nada mas llegar a casa me he puesto a montarlos.Si que es verdad que quedan con holgura sobre todo de alante a atras,yo como no tenía cinta de vitros y quería colocarlos ya,he hecho este apaño con cinta de colocar en las puertas.
(http://uploads.tapatalk-cdn.com/20160920/823393c8980b036f13f2004eac6eb241.jpg)
Así por lo menos no tiene tanto juego.
Chula chula esa Tourer compañero , y buen apaño para quitarle el poco juego que tiene los plafones de led para la matrícula [emoji106] !!!
Todavía la queda para llegar a parecerse a la tuya @Luitorr.Por cierto, para colocar la cola de escape,cambiastes la carcasa de abajo del parachoques, cuanto te costó esa pieza?, no se puede recortar simplemente?
Si os especializais en lo de la cola de escape..... Que damos un día?? So.. AmmA. .::.
Si , le podía a ver hecho el escote para la salida recortando el embellecedor , pero no queda igual ya que el detalle que lleva con relieve no es igual .... Pero como la idea era que al final fuera como viene de fabrica decidí comprar el embellecedor o defensa como quieras llamarlo con referencia: 13364471 y precio: 69,15€ más IVA y a descontar el descuento que cada uno saque en su concesionario .
(http://uploads.tapatalk-cdn.com/20160921/c659d86eb859bfd1561f3e0a44046d38.jpg)
Y así es como queda el nuevo embellecedor una vez puesto
(http://uploads.tapatalk-cdn.com/20160921/9a01663413e94d7455e4dd682428d7b0.jpg)
Que guapas las luces led. Y la cola de escape ni te cuento. Le da un aire superior
Si , la verdad que poco a poco con los cambios va mejorando progresivamente ... pero aún queda alguna cosilla más !!!
Vale, eso no parece difícil, pero enderezar el escape o cortarlo y ponerle el embellecedor del escape eso ya es otra cosa.
Exacto @Rub123 , un poco más delicado si es !!
Me seguiré fijando en las colas de escape de los demás... L''
Sí,ya me he fijado en mi carcasa y no tiene pinta de que quede bien si hago un recorte,ya que el relieve quedaría raro.
Chicos, he visto que habéis cambiado los plafones de matrícula, los he pedido en aliexpress y he visto que además de los plafones traen un cajita negra, es un transformador o algo? Como va conectado? Gracias de antemano
Yo también estoy interesado en las luces de matrícula.
Alguien podría poner el link?
La cajita negra es para que no de error de luz fundida,viene preparada para conectarla entre los plafones y el conector del coche,no tiene pérdida.
@indeciso , no te preocupes que no es complicado ... conecta los conectores que te vienen al plafón led y el de la instalación , después al sitio el plafón , dale un vistazo al hilo para ajustarlo que son un poco más pequeños y bailan un poco , te pongo algunas fotos ...
(http://uploads.tapatalk-cdn.com/20161227/d0c8e4ec0d20a137f856de29a37f8233.jpg)
(http://uploads.tapatalk-cdn.com/20161227/8a16efed22041dc7df0df216269504a9.jpg)
(http://uploads.tapatalk-cdn.com/20161227/19ac360c13d86a99f5814e3265012fbe.jpg)
(http://uploads.tapatalk-cdn.com/20161227/5b336aa6387c7240662b8db03b787e7d.jpg)
@fermin7691 yo las compré en la web de Amazon cuando las tenían a buen precio ... te pongo el link de eBay que también las tiene bien de precio !!!
Mira esto en eBay http://www.ebay.de/itm/361280948033
Y este link de la web de Alliexpress ...
Envío LED trasera Coche que labra el Número de Placas ligeras Para Astra J Raíces/Zafira-C matrícula lámpara de canbus No Error código
http://s.aliexpress.com/IZB3A3eE
Ok,muchas gracias luitorr y Toni, a ver si me pongo a montarlos. Por cierto, los míos son los de aliexpress, lo digo por si alguien no se fía que sepa que llegan, en cuanto estén montados os cuento. Un saludo y gracias
Perdona @indeciso,pero me había liado,es como ha dicho @Luitorr.Yo para que no quedasen colgando los canceladores,los encinte con los cables del coche y así evito que vayan golpeando con la chapa.
Bueno este finde puse un par de detalles que no le sientan mal a la Zafira Tourer ...
(https://uploads.tapatalk-cdn.com/20170115/314dffe58af942c0805c859dc5f26535.jpg)
(https://uploads.tapatalk-cdn.com/20170115/91db464b89d2dc55273aa763e9a35c87.jpg)
(https://uploads.tapatalk-cdn.com/20170115/39c2bd624774dacbb02bc342a6f9f890.jpg)
Pues no le quedan nada mal,por cierto, los embellecedores de los elevalunas no se iluminan,no?
Detalles y links Luitorr?
La verdad que le quedan perfectos, si señor!!!!!
Enviado desde mi E2303 mediante Tapatalk
No @Tony , no son iluminados ...
@SimonaHelp , pongo los enlaces ...
De coches de estilo de la ventana interruptor del botón de ajuste de la decoración de lentejuelas para buick encore opel vauxhall mokka Chevrolet cruze 7 unids
http://s.aliexpress.com/YZ7FF7fY
Bo SE Metal 3D insignia de alta fidelidad del altavoz de aluminio Logo Audio emblema amplificador insignia con
http://s.aliexpress.com/3MbeYriA
@sag21 , gracias !!!
Muy chulo Luitorr, sobre todo los de los elevalunas. Parece que ajustan perfectos. Son de metal o plastico ?
Son de plástico ABS de gran calidad , esa sensación me da a mi ... ya iré comentado el paso del tiempo como le influye [emoji16]
(https://uploads.tapatalk-cdn.com/20170117/39ab783ecc2050968ebb28e2df054702.jpg)
Si señor!
Enviado desde mi VFD 700 mediante Tapatalk
Ok gracias. Me animaría pero no me acabo de fiar que no se despeguen o decoloren con el uso.
Saludos !
Enviado desde mi LG-D722 mediante Tapatalk
Por lo que cuestan merece la pena , me da la sensación que tardará en pasar lo que comentas ... Pero puede ocurrir claro !!!
Te lo comento porque la cinta de doble cara que viene es de 3M y eso es calidad , ehhh !!!
Ok, igual me animo entonces .
Buenas compañeros !!!
Hoy he añadido otro detalle para mí Tourer ....
(https://uploads.tapatalk-cdn.com/20170125/10d1538b44bf8bef89fc7af1c8cb009d.jpg)
Muy chulo!!!!, los pequeños detalles marcan la diferencia, si señor!!
Gracias @sag21 , la verdad que todo lo que voy haciéndole me gusta como queda el resultado final !!
Jejeje me suena porque yo estoy a la espera de que me lleguen. Mira que queda bien eehh !!
Me alegra que os guste @sag21 @Legarthez .
Eres un crack!!
Gracias @Rub123 , sabía que te gustaría [emoji6]
Ese embellecedor lo tengo yo y la verdad que queda genial.
Bueno... pues ya estan pedidos los cromados para los pulsadores.
En la foto parece que son 7 cromados no? 5 para elevalunas y otro se le podra poner al pulsador del freno de mano electrico imagino, mas el de repuesto.
En fin.. dar las gracias a nuestro compañero Luitorr por estar al quite de cualquier producto para
nuestras Zafis... T_T
.........SALU222........
Buenas tempestad, creo que los 7 tienen función, 4 botones en la puerta del conductor, más 1 en el resto de las puertas total 7 el del freno de mano creo que no,
Así @sag21 @tempestad , son 7 piezas cromadas , para los 7 botones que tenemos en nuestra Zafira dependiendo del acabado !!!
Para el freno de mano eléctrico no viene nada ...
Ok... Gracias por la aclaracion compañeros,ni si quiera se me ocurrio pensar en los elevalunas traseros.que cabeza la mia XDD
(https://uploads.tapatalk-cdn.com/20170130/88c13cdb84591d321c821dc679bd2ffc.jpg)pues yo le he puesto estos pestillos cromados que se quedan muy bien y ne salieron tirados de precio.
Si sr. también quedan muy bien compañero , yo de momento se queda como están ... Tampoco quiero llenarlo de tanto cromado el interior [emoji6]
Bueno hoy recibí esto ...
(https://uploads.tapatalk-cdn.com/20170131/7569880176b7abee8b27cf55d9dba08c.jpg)
(https://uploads.tapatalk-cdn.com/20170131/b23d8fbc5395317a74cd15d74ddebb4c.jpg)
(https://uploads.tapatalk-cdn.com/20170131/c7ef851f28f1d6e3882e5db2b6ac94b9.jpg)
Como mola esa funda.
Donde la compraste. Tengo que conseguir una como esa!!
@Raid , es la segunda que he comprado , ya llevo una desde que saque la Tourer del Concesionario , está es para tener de repuesto ....
Carteras de casos clave De Cuero Genuino establece bolsos dominantes del coche para Mokka opel Astra Corsa Insignia Meriva Antara Zafira, 2 Botones fold clave
http://s.aliexpress.com/uiiQb6Fr
Ok. Muchas gracias. Ahora mismo la pido
Gracias a ti compañero , por estar siempre ahí [emoji6] [emoji106]
Vaya tios!! Cuesta seguiros!! No paráis con los detallitos! Y como molan todos...
Vaya pedazo de llavero o funda para las llaves ..... Que chulo . como dice el compañero no dais tregua a seguiros.
Bueno muy bonito. T_T
Ya la pedi!!! En marron. Ahora a esperar al chino del aliexpress
[emoji106] [emoji2] [emoji6]
Este hilo es un vicio.
Han caído lo de los elevalunas y el llavero.
Plis, poned los links de lo del interior de la puerta y de los pestillos también.
Gracias de antemano.
Yo tengo un par de cosillas compradas y sin poner todavía pero es que no me atrevo, a ver si lío a mi cuñado y os pongo unas fotejas.
Saludo.
Como a la nueva Zafi le falta el hueco de las gafas, he buscado un par de soluciones económicas, estoy a la espera de que lleguen, ya os contaré...
Alfombrilla antideslizante:
(https://ae01.alicdn.com/kf/UT88B8SXWhaXXagOFbXk.jpg)
https://es.aliexpress.com/item/Car-styling-mat-Interior-accessories-case-for-Opel-car-styling/32671883175.html?spm=2114.13010608.0.0.iano9P
Pinza sujeta-gafas para ubicar en el parasol:
(http://www.image-tmart.com/info_images/12010476-1.jpg)
https://es.aliexpress.com/item/Auto-Fastener-ABS-Car-Vehicle-Sun-Visor-Sunglasses-Eyeglasses-Glasses-Holder-Card-Ticket-Pen-Clip-Automotive/32693713719.html?spm=2114.13010608.0.0.iano9P
¿Alguno habeis encontrado otra solución a ese problema si es que no os han instalado el porta-gafas superior?
buenos dias.por cierto,quedan de lujo esos detalles para la ZT.una pregunta javigachi,podrias poner el enlace de los pestillos cromados?van a rosca,no?gracias
Lo de los pestillos lo he intentado poner y no me deja el movil de ninguna manera,en el buscador de aliexpress pones opel y buscando salen muchos,perdona pero lo he intentado ds verdad,si van a rosca y estan algunos muy duros pero salen,la verdad que se quedan muy muy chulos.
GRACIAS...a ver si los pongo,,,por cierto yo he colocado esto,https://www.aliexpress.com/item/Car-Inner-Front-Reading-Light-Frame-Cover-For-Opel-Vauxhall-Mokka-Buick-Encore-2013-2014-2015/32414014069.html?spm=2114.13010608.0.0.pMqu8u
Bueno continuan llegando nuevos detalles para la Zafi.
En este caso un aro para el contacto y acertar con la llave en la oscuridad 8:)
(http://i65.tinypic.com/2wheeep.jpg)
..........SALU222..........
Recibido el portagafas, no era lo que buscaba, no me parece cómodo ni adecuado para utilizarlo mientras conduces, que es lo que ando buscando pues es para gafas de sol no de ver.
Queda muy bien , tempestad, igual que el del compañero Luitorr.
Por cierto, que tipo de funda le has puesto a la llave ?? Se ve muy chula....
No es funda SrLander,es la llave de de serie a juego con el color de la Zafira.
Entonces lo consideramos una mejora de las MY 17 no ?
No todo son recortes !! O0
Cierto compañero...pequeña mejora es,pero bueno,algo es algo O0
...........SALU222..........
(https://uploads.tapatalk-cdn.com/20170301/7f8f89d2670b27d005b19b28198db512.jpg)
(https://uploads.tapatalk-cdn.com/20170301/e784e2f4e1f9b57ff96ae26c466266c1.jpg)
Ya tengo la funda de la llave a juego con la tapiceria...
Solo un mes y medio ha tardado el chino de aliexpress en traerla!!
Jajajajajaja si le a costado al chino llegar ... que chula y a juego con el interior de tu Zafira [emoji106] !!!
Bueno mas detalles pa la Zafi.En este caso unos pestillos de aluminio anonizado del chinatown ;)
Lo mejor es, que si te cansas de ellos,en 3 minutos quitar y poner.
(http://i68.tinypic.com/33nl3k6.jpg)
Igual de chulos que los del compañero @javigachi [emoji106] , quedan bien ... Ehhh !!!
Si.. No quedan mal....... O0 O0
La verdad que los pestillos los tengo yo tambien y quedan genial.
Puedes pasar enlace del aro para la llave? Gracias
Enviado desde mi Nexus 6P mediante Tapatalk
Creo que es este.
https://es.aliexpress.com/item/Ignition-key-ring-Switch-cover-keyhole-decoration-ring-sticker-For-Chevrolet-aveo-cruze-malibu-trax-LaCrosse/32561501997.html?spm=2114.13010608.0.0.JVn677
.............SALU222...........
Creo que es este.
Muchas gracias tempestad, ya lo pedí. He intentado pillar los embellecedores de los elevalunas y los mandos de la luz de cortesía pero veo que los enlaces puestos en posts anteriores ya no sirven, pone que no hay disponibles ¿alguno los habéis comprado recientemente? Gracias
Hola Damefrikis...Yo tengo puestos estos embellecedores y de la luz de cortesia los de serie.
https://es.aliexpress.com/item/Car-styling-window-switch-window-button-sequins-decoration-trim-for-buick-encore-opel-vauxhall-mokka-Chevrolet/32419136764.html?spm=2114.13010608.0.0.pUBeas
Gracias de nuevo. Estos son los que estoy tratando de pedir pero pone que no están disponibles [emoji22] habrá que esperar a ver si vuelven
Compañero @damefrikis , en el buscador escribe cromados Opel en la web de Aliexpress y te saldrán de otros vendedores para comprar los que más te cuadren de precio , mira que el envío sea gratis y el tiempo de entrega , vamos que tienes para buscar , jejejeje !!!
Javigachi podrías por favor poner el enlace de los pestillos de las puertas. Me podríais indicar los que los habéis cambiado si van a rosca o a presión?. No me gustaría estropear nada al cambiarlos.
Enviado desde mi Redmi Note 2 mediante Tapatalk
Hola,no me deja este movil poner el enlace,pon en aliexpress opel zafira y te salen todos los accesorios del coche y los pestillos,van a rosca y no hay problemas en quitarlos,alguna puerta estan muy apretados pero haciendo un poco de fuerza salen bien y como es a rosca no los vas a romper.
[img][/im[img=https://k60.kn3.net/8/4/1/4/D/5/B5D.jpg]g] bueno,al final me compre este protector....no queda mal....
no puedo colocar foto....https://kn3.net/608414D5B5DJPG.html
Muchas gracias. Ya os contaré que tal.
Muy chulo..es el mismo que puse yo.
Ten cuidado que se raya con facilidad.
Luitorr para colocar el emblema de base en los altavoces quitaste la tapa?
Hola @tontin22es , que va compañero ... No hay que quitar nada , van pegadas con cinta 3M las que puse yo , pero también venden con soporte para meterlo por los agujeros , lo que tú veas mejor !!!
OK. Gracias.
Luitorr podrías poner foto de la lámpara original que tiene la zafira de origen en luz Diurna. Gracias compañero.
@tontin22es , lo que no tengo muy claro es que lleve 1 sola bombilla la luz diurna y no sean leds , porque si te soy sincero no me he parado a mirar nada del tema , igual es parte del faro ...
Cómo recomendación personal , acércate al taller Reparador oficial y preguntas en recambios que te miren con el VIN de tu Zafira si tiene recambio tu faro de luz diurna ( me imagino que la tendrás con luz cálida ( amarilla ) y quieres poner luz fría ( white ) .
Si tengo un rato en el finde te lo miro a ver que descubrimos !!!
Exacto. Tengo de serie las amarillas. He mirado en el foro y fuera de el y he visto una barbaridad de modelos tanto Led como halogena por lo que decirse por una es complicado. Por el foro habrás visto que algunos compañeros se les calentaban demasiado mientras que a otros no les duraban. Te pedía el favor por ver exactamente cual es la que viene de serie. Si te supone un trastorno no pasa nada de verdad.
Buenas tardes, llevo tiempo desconectado. Me llegaron los pivotes cromados del cierre de las puertas pero no soy capaz de desenroscar los de serie... Qué duros están los jodíos.
Seguro que van a rosca?
Si estan bastante duros..Les puedes soltar con unos alicates pequeños y un paño para no marcarlos por si decides reutilizarlos.
Gracias! Intentaré con los alicates entonces. Ya os contaré.
Hola,si estan muy muy duros pero salen,no se van a romper por que van a rosca,yo cuando los puse dos me costaron mucho y los otros nada.
Recibida la alfombrilla, es del tamaño de la pantalla para que os hagais una idea, buena calidad y antideslizante, eso si para el tema de las gafas no lo veo muy adecuado, aunque he probado y no se caen de la alfombrilla, pero no me convence dejarlas tan a la vista cuando dejo el coche aparcado
Alguna foto para ver cómo queda [emoji6]
Añado un par de detallitos que he puesto siguiendo vuestras sabias opiniones. Por un lado la pegatina de la llave de contacto y por otro la antena de aleta de tiburón. Esta última duró menos de una hora ya que como tiene algo de curva no me convence como queda y tengo que ver cómo la ajusto (una pena porque el color y demás quedaba muy bien)
(https://uploads.tapatalk-cdn.com/20170324/90e4a840d2ad64a3cefabf027ce53018.jpg)
(https://uploads.tapatalk-cdn.com/20170324/624f8b50fdd2631042ce6be86b670243.jpg)
(https://uploads.tapatalk-cdn.com/20170324/a8d53239a161a6851f75e8d9d40987ac.jpg)
Ummm, gris Phantom como la mía... Me encanta el color
Hola a todos..os paso.unas fotillos con mis ultimas adquisiciones. Yo también me he animado a pedir cosas a China..
(https://uploads.tapatalk-cdn.com/20170325/c241977d1841a77af2aceddfdfdbe848.jpg)(https://uploads.tapatalk-cdn.com/20170325/e5ec9533a0b3dd9ca5b2278c393a6687.jpg)(https://uploads.tapatalk-cdn.com/20170325/71fbcd9df63e63b53418cc7e6774abf4.jpg)
(https://uploads.tapatalk-cdn.com/20170325/8a6bb91fd60abee4d3dcece621be59d3.jpg)
Bien compañero una funda roja para proteger el mando original y los embellecedores cromados de las manetas ... esto es un no parar , jajajaja
Sí, je, je..y en camino los detalles cromados para los elevalunas y el aro del contacto. Próximamente...
No te pases con tanto cromados que va a parecer la fiorgoneta de los malacatones .... [emoji2] [emoji6]
Espero que no !! ya es lo último.... O0
Esos detalles que vienen de camino quedan muy chulos compañero , era una expresión con un poco de humor ... jajajajaja
Por cierto @SrLander he observado que llevas molduras protectoras de las puertas,podías decir de donde las has sacado
Fue lo primero que me llamó la atención, me gustaría saber de donde salieron esas protecciones de las puertas.
Yo lo sé [emoji2] , pero prefiero que lo conteste @SrLander [emoji6]
Sí..Luitorr conoce el historial..[emoji6]
Son accesorio original Opel, pintadas a juego en el conce.
Gracias @SrLander,es bueno saber que existe la posibilidad de colocarlas.
Lo que se le escape a @Luitorr,que seríamos los de la Zafira C sin él
Y, si no es mucho preguntar ¿Como se llaman en euros?
Pues mira fueron 185 € + iva pintadas y puestas.
link del protector de llave ¿lo hay verde?
Hola @tontin22es , los faros bixenon Afl+ en la luz diurna llevan una bombilla H7 12V-55W de coste en recambios de Opel 13,65€ + IVA .( Eso según el Sr. de recambios de Opel de un Concesionario que llame por teléfono )
P.D
Te pongo la información corregida de lo que dije anteriormente ... Vaya con los de la Opel !!!
(https://uploads.tapatalk-cdn.com/20170404/bbd05cafe242c42eb90ad02e66ab006f.jpg)
@Luitorr,la luz diurna con AFL,no es de led?
@Tony Si , en el acabado Excellence el faro delantero como el trasero viene con tecnología LED .
Pero según los de recambios de Opel , NO !!!
Bombilla normal H7 55W , tengo que confirmar la explicación que me dieron [emoji15] , que los faros de la Zafira Afl+ llevan unas pantallas Led donde proyecta la luz la bombilla H7 , me han dejado con la mosca detrás de la oreja con este tema [emoji33] y creo que el trabajador no sabía bien de lo que yo le pregunté o se a liado con el otro faro con luz halógena .
Según los de recambios de Opel , NO !!!
Luitorr creo que Tony se refiere a la luz de dia que si es led y tu te estas refiriendo a la liz de apoyo en giro. Puede ser [emoji2] ?
No no @SrLander , según los de recambios de Opel lleva bombilla H7 55W en luz diurna para los que tenemos los faros Afl + [emoji15]
Pero eso es imposible..si llevamos varios segmentos de led..como va a ir una H7 ??
Eso mismo le dije yo , es más le dejé caer si este tipo de faro puede que no tenga recambio en la luz diurna y haya que cambiar el faro entero , fue rotundo su contestación NO .
Yo creo que no tenia muy claro lo que me estaba diciendo el de recambios de Opel , me pidió el número de VIN y estuvo mirando un buen rato ( todo esto por teléfono ) para decirme que llevan H7 55W , el lunes tengo que ir a preguntar unas cosas y esta será una de ellas .
La llamada esta tarde me dejó un poco tocado con el tema ...[emoji24] .
Yo aún no he mirado si se puede meter mano al faro para ver lo de la luz diurna .
Bueno creo que ya he dado con algo más de información sobre la luz diurna en los faros Afl+ , ( me parece a mi que le debo una llamada al Sr. de recambios que me atendió ) .
(https://uploads.tapatalk-cdn.com/20170404/e278d94cf48da591d032843ca4cb1e31.jpg)
Eso me cuadra más,para mi que se lió con las de giro,aunque no sé si estás son H7
Hola @Tony , se lío pero bien ( pero no me lo confirmaron en un solo Concesionario los de recambios , si no en varios ) .
Las luces de iluminación estática en curvas o luces de giro si llevan H7 55W , eso si lo puedo asegurar ... Que he cambiado las de origen por la Philips WhiteVision .
Buenas tardes a todos. Antes de nada dar las gracias a luitorr por molestarse en aclararme la duda que tenia sobre el tipo de lámpara de la luz Diurna. Al poco tiempo de realizar la pregunta me pasé por el concesionario a pasar la primera revisión la del año y aproveche para preguntar. Me dijeron lo mismo que a ti. Lo estuvo mirando en el despiece con mi vin y me dijo que llevaba la h7 de luz Diurna. Flipante. Un compañero de trabajo que tiene la diésel de 170cv acabado excelente pregunto en otro concesionario y le dijeron que el modelo que lleva al tiene la luz Diurna con tira de Led no va con lámpara.
No tienes que darme-las compañero , como tú bien dices es flipante lo que se preocupan algunos trabajadores de Opel por saber el despecie de recambios o accesorios de un vehículo ( menos mal que ellos disponen del programa) en fin !!!
Bueno ya tenemos otro dato más claro clarinete respecto a la luz diurna con los faros bixenon AFL+ , iluminación estática en curvas ( luces de giro ) , etc ...
Lo que no me explico es que digan que llevas una lámpara h7 como luz diurna y no les extrañe
@Tony pues te puedo decir que le insistí por activo y pasivo ... le comenté que no eran los faros con luz diurna cálida ( amarilla ) con bombilla halógena , le dije que estábamos hablando de los faros adaptativos AFL+ con luz diurna blanca y bixenon , y al final de la conversación me colgó con que eran bombillas H7 12V 55W y el precio de 13,65€ .
Yo lo puse en el hilo donde me pregunto el compañero tontin22 que tipo de bombilla lleva mi Zafira , para ver vuestras reacciones y opiniones sobre el tema , ya he visto que en este foro hay mucha gente por no decir la mayoría que estáis más preparados y tenéis más información y sabiduría que muchos que están en los Concesionarios de Opel !!!
Bueno otro detalle más para mi querida Zafira Tourer , ahora toca disfrutar y relajarme en las vacaciones de Pascuas !!!
(https://uploads.tapatalk-cdn.com/20170411/2c6320f32cdeba9c1da17cc79d5aee3e.jpg)
Luitor muy chula la antena se la has comprado por aliexpress yo se la pille alli y esta muy bie lo unico que tiene 1 milimetro que no encaja
Enviado desde mi SM-G930F mediante Tapatalk
Einnnn [emoji15] , la antena és la de fàbrica que lleva el acabado Excellence con Onstar [emoji6] .
No soy capaz de desenroscar los pestillos de las puertas para poner los metálicos... Ninguno de los cuatro, ideas?
que es esa especie de compartimento debajo del reposa cabezas?
Si te refieres a la base del FlexConnect , es para acoplar una bandeja , una percha o el soporte de la tablet ... vamos un sistema de Opel !!!
Yo he puesto los pestillos y dos salieron bien,pero los otros dos me costo muchisimo y me hice hasta daño quitandolos pero salieron jeje.
Enviado desde mi LG-H815 mediante Tapatalk
Hola Luitor. Muchas veces sigo tus comentarios, pero por falta de tiempo, no puedo hacerlo diariamente.
Tengo una cuestión ke hacerte. Quisiera cambiar la luz de giro por una de luz blanca, alogena, ya ke la ke trae de serie da luz amarilla y keda muy mal con los bixenon del AFL +. Me refiero a la luz ke enciende en giros pronunciados de hasta 90º. Sabes si hay alguna cosa para esto?? Un saludo
Enviado desde mi ASUS_Z00AD mediante Tapatalk
Hola @Kicho , que tal ...
Se agradece tu comentario [emoji106] , el compañero Raid y servidor estuvimos probando varias bombillas H7 de Philips en concreto las Philips WhiteVision y las Philips Diamond !!!
Lo que sacamos en claro fue que ninguna de los 2 modelos se acercaban a la luz de los Afl+ , pero que las que mejor le iban eran las WhiteVision ( pasan ITV ) que aún siendo amarillenta eran bastante más blancas que las de origen , la otra opción las Diamond ( no pasan ITV ) son blancas azuladas y depende el enfoque cantan más a la vista !!!
Al final pusimos las Philips WhiteVision por homologación [emoji106] !!!
Philips 12972WHVSM WhiteVision Bombilla para Faros Delanteros con Efecto Xenon H7, 2 Unidades https://www.amazon.es/dp/B00MZQUIRW/ref=cm_sw_r_cp_apa_T60vzb1K4CYM6
BOMBILLAS DE MEJORA DE FARO PHILIPS DIAMOND VISION H7 5000k https://www.amazon.es/dp/B007JZKBVW/ref=cm_sw_r_cp_apa_y70vzbV9KAPTZ
Gracias Luitor. Vuestro desinterés con este foro, no tiene precio. Me voy a decidir por las efecto xenon. En otro momento te preguntare por el " maravilloso " navi 950..... si ha aparecido algo nuevo ke nos mejore este sistema de mi.....da.
Un saludo y gracias de nuevo
De nada compañero , no conocemos tu Zafira en fotos , no ?
De momento no hay nada para el Navi 950 sin tener que pasar por caja o cambiar el equipo de entretenimiento , algún compañero en otro hilo puso información sobre el famoso Navi950 !!!
Yo de momento mientras esté en garantía la Tourer no tocaré nada , después .....[emoji6]
Cuando las cambies ya dirás tus impresiones y valoraciones , se agradecerá [emoji106]
No. Todavia no hice ninguna foto, pero la verdad es ke estoy bien contento. Un dia ya os comenté ke es mi tercera zafi. Tuve los tres modelos A, B y C tourer. Ahora en vacaciones colgare
Pues @kiko , si has tenido las tres generaciones del Zafira ... eres un auténtico chico Opel [emoji6] , a parte de conocer lo bueno y lo malo de cada una de ellas [emoji106] !!!
