Autor Tema: When does the spanner warning light comes on? When should it go off?  (Leído 2296 veces)
kaliope
When should the spanner light go off? When does it come on and stay on?
https://www.youtube.com/watch?v=cYtTH7HkyWI
Luitorr
Re:When does the spanner warning light comes on? When should it go off?
« Respuesta #1 en: 19 de Mayo de 2017, 22:24:06 pm »
Valuable companion information, thank you very much !!!
« Respuesta #2 en: 20 de Mayo de 2017, 00:07:38 am »
Valuable information, but I have the second situation, and if I do the pedal test trick, I don't have any code.
What can I do?
« Respuesta #3 en: 20 de Mayo de 2017, 06:16:04 am »
What can I do?
there are codes what don't see whit the pedal test  trick,
you can see the error codes whit a opcom  or similar dispositive.
Como es fácil que de mi ingles de EGB no se entienda, que hay códigos de fallos que no salen con la prueba de pedales, puedes verlos con un opcom o similar
kaliope
« Respuesta #4 en: 20 de Mayo de 2017, 07:37:55 am »
Yes, the pedal test usually shows only 'P' error codes, that is connected with the engine.
You can have:
P - engine
C- chassis
U - electrics
B- body
« Respuesta #5 en: 20 de Mayo de 2017, 08:10:34 am »
What can I do?
Ok, se te entiende perfectamente, a mi se me apaga justo cuando se apaga la del aceite, a ver si me hago con un opcom y lo miro.
You can have:
P - engine
C- chassis
U - electrics
B- body
Thanks for the information, I'll look at it when I have an opcom.
The light turn off when the oil light does.
« Respuesta #6 en: 20 de Mayo de 2017, 15:35:25 pm »
Ok, I'm happy if it you understand me.
My zafira have a one electric error code, it's a interruptor  brake light.  Appears eventually and only goes out. I will change the interruptor in the future.
Sorry for the mistakes
« Respuesta #7 en: 21 de Mayo de 2017, 19:45:15 pm »
Thank You - Gracias  O0
